QoS Class-Based Traffic Shaping (what is Be)
kfarrington
Level 3
Level 3
Guys,
two questions on the output below :
1. What is the Be, is this an amount per interval that can go over Bc or is it the total amount of data that can be sent?
ie, i interpret the command to read, Bc is the sustained rate per interval and Be is the sustained rate plus another amount, it I would use sommat like this
shape average 128000 7936 8500
this would show that I could send in total up to 8500 bits per interval
or does it work like this ?
shape average 128000 7936 564
if it is the first one, you would not expect to be able to configure a Be of less than Bc?
Also, how can you show what traffic is within the Bc and what is in the Be? ie, how much data is being sent out of contract?
Many kind regards,
Ken
Metro2(config-pmap-c)#policy-map test1_cos
Metro2(config-pmap)# class class-default
Metro2(config-pmap-c)# shape average ?
<8000-154400000> Target Bit Rate (bits per second), the value needs to be
multiple of 8000
percent % of interface bandwidth for Committed information rate
Metro2(config-pmap-c)# shape average 128000 ?
<256-154400000> bits per interval, sustained. Needs to be multiple of 128.
Recommend not to configure it, the algorithm will find out
the best value
<cr>
Metro2(config-pmap-c)# shape average 128000 7936 ?
<0-154400000> bits per interval, excess. Needs to be multiple of 128. Bc
will be used if you don't configure it.
<cr>
Metro2(config-pmap-c)# shape average 128000 7936 1000 ?
<cr>
Metro2(config-pmap-c)#^Z
Metro2#
Metro2#sh policy-map int fa 0/1 out
FastEthernet0/1
Service-policy output: test1_cos
Class-map: class-default (match-any)
5476 packets, 1934775 bytes
30 second offered rate 0 bps, drop rate 0 bps
Match: any
Traffic Shaping
Target/Average Byte Sustain Excess Interval Increment
Rate Limit bits/int bits/int (ms) (bytes)
128000/128000 1117 7936 1000 62 992
Adapt Queue Packets Bytes Packets Bytes Shaping
Active Depth Delayed Delayed Active
- 0 5476 1934775 967 1448313 no
Metro2#
Metro2# conf t
Enter configuration commands, one per line. End with CNTL/Z.
Metro2(config)#policy-map test1_cos
FastEthernet0/1
5479 packets, 1934955 bytes
Match: any
Traffic Shaping
128000/128000 1984 7936 7936 62 992
- 0 5479 1934955 967 1448313 no
Metro2#
3 Accepted Solutions
ybajpai
Be in class-based QOS is incremental. meaning Bc + Be bits can be sent per interval when Be is configured. This information and more can be found here:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fqos_c/fqcprt4/qcfpolsh.htm#wp1001093
(Url may have word wraps)
Yash
When u use average option u can send only Bc per interval.Unlike peak option it won't send Bc+Be per interval. But Whenever less than the burst size is sent during an interval, the remaining number of bits, up to the Be size, can be used to send more than the burst size in a later interval.
When u use peak option u can send Bc+Be per interval. Sending in peak rate may result in dropping during the time-period of congenstion.
I hope this will clear ur doubt.
Hi Ken
as the others mentioned there are two ways of shaping, average and peak. You can give 3 options to each of them, first the mean-reat (cir), then the bc (burst-commited) and the be (burst-excess) size. Each time intervall the interface may send bc, no mater if you shape to peak or to average. With be it is a bit different, if you shape to peak, it can also send each intervall the be size, so shape peak means sending each tc (time intervall) be+bc.
Shape average is a little different. You have to think of shaping as a system of token buckets, which get some new tokens each tc, the bc bucket gets full each tc, and if it is not used fully, and it gets refueled the next tc, the tokens overflowing are flowing into the be bucket, so the next tc, it may send bc plus what is in the be bucket.
So actually the only differenc in shaping to average or peak is the way that the be bucket gets refueled, either by getting refueled completly each tc (peak) or by getting what overflows be (avarage).
By the way, if you don't specify the be or bc value, IOS does it for yourself. At speeds lower then 320 kbps it always asumes bc=8000bits, at higher speeds it uses a tc of 0.025 seconds to calculate bc (be is always asumed as the same size of bc). So you see, you can adjust the tc intervall by changing the be because tc=bc/CIR!
There is a extremly good book about that on Cisco Press, "CISCO QOS Exam Certification Guide 2nd Editon", which explains all the shaping and policing concepts in a very understandable way.
Hope that clarifies your questions a bit.
Simon
8 Replies 8
ybajpai
Yash
balajitvk
Level 4
Level 4
When shape average is configured, the interface sends no more than the Bc size for each interval, achieving an average rate no higher than the CIR.
So u can send only 7936 bits per interval. not more than that.
When the shape peak command is configured, the interface sends Bc plus Be bits in each interval.
if needed u can refer this link,
http://www.cisco.com/en/US/products/hw/switches/ps669/products_configuration_guide_chapter09186a008007f1e8.html
Guys,
this is great stuff and I really apprciate it.
The thing is this.
One one URL it says the following :-
For Class-based Shaping - How it Works
When the Be size equals 0, the interface sends no more than the burst size every interval, achieving an average rate no higher than the mean rate. However, when the Be size is greater than 0, the interface can send as many as Bc + Be bits in a burst, if in a previous time period the maximum amount was not sent. Whenever less than the burst size is sent during an interval, the remaining number of bits, up to the Be size, can be used to send more than the burst size in a later interval.
The other URL says :-
DTS How It Works
The Be size allows more than the Bc size to be sent during a time interval under certain conditions. Therefore, DTS provides two types of shape commands: average and peak. When shape average is configured, the interface sends no more than the Bc size for each interval, achieving an average rate no higher than the CIR. When the shape peak command is configured, the interface sends Bc plus Be bits in each interval.
So which one is correct. I am really confused.
As far as I am aware, I am running CB Shaping and not DTS, but when I go into the router configurations I get both options.
average and peak ?
Please see example :-
Metro2(config-pmap)#class class-default
Metro2(config-pmap-c)#shap ?
adaptive Enable Traffic Shaping adaptation to BECN
average configure token bucket: CIR (bps) [Bc (bits) [Be (bits)]],
send out Bc only per interval
fecn-adapt Enable Traffic Shaping reflection of FECN as BECN
fr-voice-adapt Enable rate adjustment depending on voice presence
max-buffers Set Maximum Buffer Limit
peak configure token bucket: CIR (bps) [Bc (bits) [Be (bits)]],
send out Bc+Be per interval
Many kind regards and thx for the help with this :)
Ken
it does many thanks. - thats great :))
so you can only send Bc in shape avg, but if you only send half of Bc in one interval, on the next interval you could send Bc plus the extra bits (that you did not use in the last interval) to make the shaper hit the target rate?
Thats what you are saying right?
Also, when you say later interval, do you mean next interval
Best regards,
Ken
Guys,
I suppose what I am saying is.
I am using the CB shaping average command
class class-default
So does this mean that I WILL NEVER use Be even though it shows in the output in the policy-map
The only way I would ever use Be with CB shaping would be with the shape peak command
And then the shape peak command is Bc + Be that could potentially be sent in one time interval (dependant on the last interval not acheiving its max rate for Bc)
If someone could clarify that these statements are correct, there is many truck loads of BEER for them :)
Kind regards,
Ken
Hi Ken
Simon
Simon,
WOW I am off to buy this book. That is a brilliant way of putting it Simon - Thx
Many thx to youj and all for the help :))
beers in the post!
