Webcast-Catalyst9k
QOS & COS Design Help
Hi All,
First off I would like to state that my field of knowledge with these two subjects are very limited. That being said I am going to go ahead and explain my situation.
We have two sites connected to each through a leased 100 MEG MPLS. Each of these sites runs on a router on a stick concept, with layer 3 switch as the core routing solution.
In site 1 VLAN 6 is our voice vlan. In site 2 VLAN 5 is the voice vlan.
Site 2 has to reach Site 1 as our main PRI's are all in this site.
So I am under the assumption that I have to COS all VLAN 5 Traffic. The core L3 switch would then QOS all traffic headed to the IP address over at SITE 1 which is the main voice server w/ PRI's etc.
Conceptually thats what i understand I might have to do. I could be totally wrong.
can someone please shed some light on what the best way to go about this is?
I dont have any access to the leased line MPLS unforunately.
Everyone's tags (4)
Silver
Re: QOS & COS Design Help
Hi Steve,
u might already solve it but lets see if this information can help
yes you need to trust cos fron your site 2 if its layer 2 inter face and trust DSCP on layer 3 interface,
check this document and hopefully it will help you.
Please rate if this helps.
cheers
Hi Amrinder,
I am not sure if you can or will continue helping me with this problem, but I now have the time and resource to now tackle this problem.
I have read your document, and i have also purchased Cisco Catalyst QoS to help gain some great understanding of QoS.
I want to break down my problem or I should say procedure one step at a time, starting at the access layer on a Catalyst 2960.
My current default config is as follows for my access layer ports. I have a Mitel Voip Phone Connected to the Catalyst.
interface GigabitEthernet1/0/9
description Gi1/0/9 SRAdm&Voip
switchport access vlan 10
switchport mode access
switchport voice vlan 6
mls qos trust cos
My Phone is set for a CoS Priority of 5. It is also set for a DSCP value of 46. (I chose this as it is the default value for EF)
I have added the line:
mls qos trust cos
to trust the cos of the tagged frames the phones puts out and to leave untagged frames with a default value of COS 0.
The only thing I have not done yet is enable mls qos globally.
I just want to confirm if so far my steps are correct. Also i realize I will have to do a cos-dscp mapping so that COS 5 is equal to DSCP 46.
So far is there anything I am missing?
Now since this is only an access layer switch, which connect directly to our core switch, I realize I will have to trust the uplink ports. What would the config be for those?
Would it also be:
mls qos trust cos
or
mls qos trust dscp
Thanks in advance.
Steve
507
