QoS, NBAR, and NAT - Help
All,
When using NAT, I understand that the translation is done BEFORE QoS is applied for inbound-to-outbound traffic. If this is correct, how would an ACL look if I wanted to restrict one host on the inside from going out a certain port?
Public IP: 5.5.5.5
Private IP: 192.168.1.50
If a service policy is applied as output on the public interface, then QoS would match on the 5.5.5.5 address, but if I wanted to restrict cnn.com, I would restrict everyone behind that address. Is there a way to restrict just the one host?
I've been using NBAR and I can't get anything to match, for whatever reason, so I'm wondering if it has something to do with NAT. Does anyone have a good example of a config that is using NAT, NBAR, and blocking either whole websites or, better yet, mime types?
John
HTH, John *** Please rate all useful posts ***
1 REPLY
Community Member
Re: QoS, NBAR, and NAT - Help
Use NBAR to mark the traffic. Then use an ACL blocking 192.168.1.50 to any IP that has that marking.
So, just an example...
class-map match-any CNN
match protocol http url "*cnn.com*"
policy-map CONTROL-HTTP
class CNN
set ip dscp 1
ip access-list extended 110
permit ip host 192.168.1.50 any dscp 1
ip access-list extended DROP
deny ip any any
interface lo200
desc *** My Black Hole ***
ip address 200.200.200.200 255.255.255.255
ip access-list DROP in
route-map BLACK-HOLE-HTTP
match ip address 110
set ip next-hop 200.200.200.200
interface Fa0/0 !(inside int here)
service-policy input CONTROL-HTTP
ip policy route-map BLACK-HOLE-HTTP
end
1108
