QOS trust-ipprec on 6000 does not seem to be configurable
I try to configure set port qos 6/1 trust trust-ipprec on a Cat6000 with CatOS 6.3.3. The port is on a WS-6348-RJ-45. The Cat doesn't accept the command. The bug toolkit has not shown me any known issues. Has anybody made similar experiences ? Any workaround ?
Mat
Prashanth Krishnappa
It's not a bug.."trust-ipprec" is not supported on WS-X6348. It is supported in cards with newer ASICs such as WS-X6548
You can configure ACLs to overcome this limitation
