QoS using PPP Encap and Multilink
I have a 3640 connected to a 2620 via a synch serial T1. The 3640 has a NM-2FE-2W with a VWIC-2MFT-T1. The 2620 has a WIC-1DSU-T1 (Part #'s should be right). The following link describes what I'm trying to do: http://www.cisco.com/warp/public/788/voice-qos/voip-mlppp.html However, I can't even get the link to come up...some sort of PPP problem. Please give any suggestions on the following configs:
3640 ROUTER
interface Multilink1
description Connected to TXDOT2620
bandwidth 1544
ip address 172.20.1.29 255.255.255.252
ip hello-interval eigrp 1 60
ip hold-time eigrp 1 180
ip authentication mode eigrp 1 md5
ip authentication key-chain eigrp 1 EIGRPKeyChain
no ip route-cache
no ip mroute-cache
fair-queue
no cdp enable
ppp multilink
ppp multilink fragment-delay 20
ppp multilink interleave
multilink-group 1
ip rtp priority 16384 16383 400
interface Serial2/0:0
description Linked to Interface Multilink 1
bandwidth 1544
no ip address
no ip redirects
encapsulation ppp
no ip route-cache
no fair-queue
no cdp enable
ppp multilink
multilink-group 1
2620 ROUTER
description Connected to Cisco3640
bandwidth 1544
ip address 172.20.1.30 255.255.255.252
no ip route-cache
no ip mroute-cache
no logging event link-status
fair-queue
no cdp enable
ppp multilink
multilink-group 1
interface Serial0/0
bandwidth 1544
no ip address
no ip redirects
encapsulation ppp
no ip route-cache
no ip mroute-cache
no fair-queue
no cdp enable
ppp multilink
multilink-group 1
  • Other Network Infrastructure Subjects
1 REPLY
Re: QoS using PPP Encap and Multilink
try debugging PPP authentication. I have seen in some cases where the ppp connection is trying to negotiate some authentication parameters (CHAP). So try to enable CHAP authentication (locally on the routers) it might solve your problems.
Hope this helps.
Ciao
294
