QPM, CW WAN, and CW LAN
We have a new server and new version of CiscoWorks LAN Mgr. The server is dual Xeon 1.3G processors with 1 GB RAM. Can I also safely load CiscoWorks Routed WAN Mgr and CiscoWorks QPM on the same box? Thanks.
1 REPLY
Blue
Re: QPM, CW WAN, and CW LAN
Even though that the install doc only mentions about Pentium processors, there should not be any problems installing both on the saem Xeon based server. Though, if you can install both on separate servers, that's even better.
87
