Webcast-Catalyst9k
QPM - Modifying device constraints
Does anyone know how to more efficiently modify device constraint? I have tried to modify device constraints, eg from FR PVC to a Subinterface (for defining a policy-map that has been defined in a FRTS configuration, but I can't delete the constraint, and I can't add any other constraints! (Becuase I can't change the FR PVC section). The only thing that I can do it seems, is to create a whole new policy-group, with the new device constraint that I want. This seems a bit of a waste of time to me, and I would have thought that there is a more efficient way to do this. Is there?
1 REPLY
Silver
Re: QPM - Modifying device constraints
I am not sure about others, but you can modify the device constraints on the QPM using the IP telephony wizard to modify the voice templates and policy groups.
95
