Spotlight January 2018 Silver
Question about configuring Etherchannel on Catlyst 3750
Hi, I have a stack witch catalyst 3750, I mean I have 3 switches ( 1 master, 2 slaves)
My question
Can I configure an etherchannel having 2 interfaces on each switch?
How can I do this?
1 REPLY
Purple
Re: Question about configuring Etherchannel on Catlyst 3750
If you have a stack it should present itself as a single switch just put channel-group 1 desirable nonsilent if you are going to another cisco on each of the interfaces you want in the channel . this is for a layer 2 etherchannel . For a layer 3 etherchannel is somewhat more involved and too long to write here , just go to the cisco.com site and search on configuring etherchannels,3750 .
130
