Question about input queue in show interfaces output
I have a catalyst 4006 with processor III, level 3, and in the show interfaces output the “input queue” in very very high, in several of they, but no droop paquets.
For example
FastEthernet2/47 is up, line protocol is up
Hardware is Fast Ethernet Port, address is 000a.8a35.03be (bia 000a.8a35.03be)
Description: "acd"
MTU 1500 bytes, BW 10000 Kbit, DLY 100 usec,
reliability 253/255, txload 1/255, rxload 1/255
Keepalive set (10 sec)
Half-duplex, 10Mb/s
Last input 00:00:06, output never, output hang never
Last clearing of "show interface" counters 20:14:51
Input queue: 1714889/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
1810861 packets input, 360397463 bytes, 0 no buffer
Received 15945 broadcasts, 0 runts, 0 giants, 0 throttles
18307 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
2623836 packets output, 329147904 bytes, 0 underruns
35247 output errors, 35183 collisions, 0 interface resets
0 lost carrier, 0 no carrier
I see that the input queue is “”Number of packets in output and input queues. Each number is followed by a slash, the maximum size of the queue, and the number of packets dropped because of a full queue. “” but I have a doubt.
The question is ¿ this input queue high is a dangerous condition for the catalyst ó what means ?
And other question is ¿ this counter cab be reseted and how ?
Please help me,
Bronze
Re: Question about input queue in show interfaces output
Yes, this could become a problem if left unattended to. It might halt your Switch from forwarding any more packets.
Most of the times, this could be due to software bug (buffer leak) and upgrading to a latest version of IOS might fix the issue.
In case you cannot upgrade right now, you could try the 'show buffers old' and 'show buffers input-interface FastEthernet2/47'
commands to pinpoint the source of the buffer leak and filter the problematic packets.
This documents explains the process in more detail.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_tech_note09186a00800a7b85.shtml
OK, then I will look for source of buffer leak
Thank for your help
Fernando
208
