Webcast-Catalyst9k
question about using "ip ospf demand circuit"
Hi All,
When using "ip ospf deman circuit", must I also not use "broadcast" parameter in the "dialer map " command in bri interface? I hear that the " broadcast" parameter will make the circuit up even if there is no topology change. Anybody has idea? Thank You!
Best Regards
Teru Lei
1 ACCEPTED SOLUTION
Silver
Re: question about using "ip ospf demand circuit"
On broadcast media OSPF demand circuits will not successfully suppress the Hello's, it will only work successfully on point-to-point networks and point-to-multipoint non-broadcast networks
You need to use the IP OSPF NETWORK NON-BROADCAST command to change the interface to a non broadcast media on ISDN or configure it as a point-point interface
The following URL has some good tips on the use of OSPF demand circuits and reasons why the link may stay up - incluing the use of broadcast on ISDN configs:
http://www.cisco.com/en/US/customer/tech/tk826/tk365/technologies_tech_note09186a008009481b.shtml
Silver
Bronze
Hi Teru Lei
There is an issue about broadcast and demand circuit but it think it's not the
broadcast in the dialer map.
As i rememeber it's the ospf interface typ which should not be broadcast.
If you type "sh ip ospf interface" it will show you the ospf network type.
1600#sh ip ospf interface
Serial0 is up, line protocol is up
Internet Address 10.0.0.2/30, Area 0
Process ID 1, Router ID 20.20.20.20, Network Type POINT_TO_POINT,
Cost:64
Transmit Delay is 1 sec, State POINT_TO_POINT,
Timer intervals configured, Hello 10, Dead 40, Wait 40, Retransmit 5
Hello due in 00:00:09
Index 1/1, flood queue length 0
Next 0x0(0)/0x0(0)
Last flood scan length is 0, maximum is 0
Last flood scan time is 0 msec, maximum is 0 msec
Neighbor Count is 0, Adjacent neighbor count is 0
Suppress hello for 0 neighbor(s)
You can change the type with "ip ospt network " on the interface level.
Hope that helps you.
Roger
108
