question on IP statistics
I have two Cisco 1601 routers (eth0 10Mpbs/half only) connected as follows
LAN (10/100 Mbps) 10.0.1.0/26 --->3com switch (10/100 MBPS)--->Router1601-A-->csu/dsu--leased line--csu/dsu<--Router1601-B<---NetGear Switch (10/100 Mbps)<--- LAN (10/100 Mbps) 10.0.2.0/28
For both routers : eth0 - ARPA. se0 - HDLC.
both of them has increasing collisions & deffered counts on eth. No late collisions. No excessive collisions. No prob at the serial side - counters are clean. i am getting this on "sh ip traff"
what does the ff indicate / mean :
1. bad hops count
2. not a gateway count
3. encapsulation failed count
4. no route count
they're incrementing..
RouterA#sh ip tra
IP statistics:
Rcvd: 6947190 total, 151408 local destination
0 format errors, 0 checksum errors, 804 bad hop count
0 unknown protocol, 7164 not a gateway
0 security failures, 0 bad options, 0 with options
Opts: 0 end, 0 nop, 0 basic security, 0 loose source route
0 timestamp, 0 extended security, 0 record route
0 stream ID, 0 strict source route, 0 alert, 0 other
Frags: 0 reassembled, 0 timeouts, 0 couldn't reassemble
0 fragmented, 0 couldn't fragment
Bcast: 138633 received, 5238 sent
Mcast: 0 received, 0 sent
Sent: 212105 generated, 193330 forwarded
14124 encapsulation failed, 6580364 no route
Thanks. I need help badly.. pls. help...
1 REPLY
Re: question on IP statistics
first,can you tell me what do you mean by "ff" in sentence:what does the ff indicate / mean :
I can give you two suggestions
1,manualy set the speed of switch connected directly to the router to 10M,duplex to half
2,Make sure every PCs in the LAN have the right gateway address
3,Check the statistics on the 3com switch NetGear Switch to get more information
hope it help
205
