I would like to ask.. what does the ff indicate or mean :
1. bad hop count
2. not a gateway count
3. encapsulation failed count
4. no route count
<--excerp-->
RouterA#sh ip tra
IP statistics:
Rcvd: 6947190 total, 151408 local destination
0 format errors, 0 checksum errors, 804 bad hop count
0 unknown protocol, 7164 not a gateway
0 security failures, 0 bad options, 0 with options
Opts: 0 end, 0 nop, 0 basic security, 0 loose source route
0 timestamp, 0 extended security, 0 record route
0 stream ID, 0 strict source route, 0 alert, 0 other
Frags: 0 reassembled, 0 timeouts, 0 couldn't reassemble
0 fragmented, 0 couldn't fragment
Bcast: 138633 received, 5238 sent
Mcast: 0 received, 0 sent
Sent: 212105 generated, 193330 forwarded
14124 encapsulation failed, 6580364 no route
If the values mentioned above keeps incrementing.. what does that mean or indicate? do i have a problem (where)?
pls. i really need help...
thanks
