04-07-2004 01:24 PM - edited 03-02-2019 02:52 PM
Hi all. I just wanted to throw this out there incase anyone has run into any issues.
Right now, I have 2 6500's with 2 MSFC's in each PFC2's etc. They are both running Hybrid (CatOS 8.2(1), MSFC 12.1(20)E2. Identical hardware.
I would like to run SRM in both (for line card redundancy), as well as HSRP between chassis for layer 3 redundancy and chassis redundancy.
Does anyone see an issue with this configuration?
04-07-2004 05:21 PM
You are on the right track.. SRM for MSFC redundancy in the chassis and HSRP for chassis redundancy is the way to go
04-07-2004 05:32 PM
Thanks. I just wanted to see if anyone had any issues with doing this sort on config. Or any caveats, of going with this configuration that i should be aware of.
