Questions about output drops on an interface
I am getting the following when I do a show interface. What does "Total output drops" mean and should I be worried?
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 53
Queueing strategy: Class-based queueing
Output queue: 0/1000/64/53 (size/max total/threshold/drops)
Mike
1 ACCEPTED SOLUTION
Silver
Re: Questions about output drops on an interface
Output drops indicate that your interface had become overwhelmed with outbound traffic. Whether or not to be worried depends on the frequency of drops; in the "sh int" command you can use the packet count with this information to calculate the packet drop ratio. If it is in the low single digits, I wouldn't sweat it. If it is more than that, you might need to look into your traffic management policies and come up with a strategy that avoids dropping important traffic. This often includes getting more bandwidth ;)
HTH pls rate!
Silver
HTH pls rate!
Thanks that helped. My drops were 53 output drops for 860036 output packets so it looks like I should be fine.
Mike
How we solve it, how much i need to increase the hold-quee ???
Super Bronze
Disclaimer
The Author of this posting offers the information  contained within this posting without consideration and with the  reader's understanding that there's no implied or expressed suitability  or fitness for any purpose. Information provided is for informational  purposes only and should not be construed as rendering professional  advice of any kind. Usage of this posting's information is solely at  reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever  (including, without limitation, damages for loss of use, data or  profit) arising out of the use or inability to use the posting's  information even if Author has been advised of the possibility of such  damage.
Posting
"Solving" drops can be quite complex.  Sometimes "solving" doesn't totally eliminate drops, but "solving" often does minimize the number of drops.
Drops can be used for TCP flow control.  When used in this role, the idea is to drop the minimum number of packets to have the flow's source send at about the available bandwidth.
Increasing queue depth often, but not always, will mitigate drops but it also can increase latency.  I.e. "solving" drops might warrant decreasing queue depth, although not often done on Cisco devices since their default queue depth usually isn't too large.
For TCP, optimal queue size should support BDP (the bandwidth delay product).  Too small a queue leads to premature drops, too large a queue leads to needless queuing latency.
Super Bronze
Disclaimer
Posting
BTW, I recall Cisco recommending only being concerned when drop percentage exceeds 1%, although I don't recall whether this was per hop or end-to-end (the latter makes the most sense).  This recommendation didn't, I believe, take into account different kinds of traffic, for example even 1% might be too high for VoIP but a bulk data transfer using TCP could probably go a little higher.
984
