Community Member
Queue Size of cisco switches
Hi!
I want to know how much input/output queue sizes(in pkts or bytes) cisco switches(e.g., catalyst 2970G) have. I searched whole the internet but the one thing I found was the size DRAM of the switches.
Furthermore, 'show interfaces' command is supposed to show the number of packets in INPUT/OUTPUT queues but the results are always 0/75(max, input) and 0/40(max, output). The maximum sizes(75, 40 pkts) are unconvinceable either.
Please help me with this issue!
1 REPLY
Re: Queue Size of cisco switches
hi
The Cisco Catalyst 2970 Series Switch supports four egress queues per port.
for more info on the same would suggest to refer the datasheet..
http://cisco.com/en/US/products/hw/switches/ps5206/products_data_sheet09186a0080197384.html
regds
354
