09-14-2006 12:10 AM - edited 03-03-2019 05:01 AM
we want to implement MSTP at customer side. unfortunately there are some legacy switches who don't understand MSTP.
so we'll have to implement a "hybrid scenario" where the "core" speaks MSTP using instances and the access-switches are
using their "old" spanning tree protocol (talking with the Instance 0 of the MSTP).
now my question:
when the core is migrated to MSTP, is the IST Spanning Tree able to talk with legacy switches in a "rapid way"
(if the support it)?
i found a cisco document which deals with this topic, but i'm not completely sure that it answers my question....
Rapid-PVST+ Interacting with MSTP
An MSTP switch interacts with a Rapid-PVST+ switch in the same way that an MSTP switch interacts
with PVST+ switch. (See IST Interacting with PVST+.) The MSTP switch will send IST BPDUs in
802.1D format on all VLANs to the Rapid-PVST+ switch and IST will consider the port connected to
the Rapid-PVST+ switch to be at the boundary of the MST region.
Has anyone of you experience with such "hybird" MST/Rapid-PVST+ configurations?
thanks a lot for your answers &
kind regards,
Bernhard
Solved! Go to Solution.
09-14-2006 12:27 PM
Hi Bernard,
In that scenario, as mentioned in the document, the MST region is going to send plain STP BPDUs to the rapid-PVST region. So basically, only STP will be run at the boundary between MST and rapid-PVST. In particular, there will be no proposal agreement possible on the vlans because MST only runs one instance (the CIST, instance 0), while rapid-pvst runs several instances (one per vlan). So the MST side does not have a per-vlan context that would allow it to answer the proposal from each individual PVST+ instance. To be honest with you, that could probably have been enhanced, but the interaction rapid-PVST/MST has never been a priority, as we hope that customers will be able to migrate the whole network to MST and only use this interaction as a temporary solution.
Francois
09-14-2006 12:27 PM
Hi Bernard,
Francois
09-14-2006 12:28 PM
PS: sorry for the spelling error in your first name. I wrote it as a French name, personal bias;-)
10-05-2006 12:47 AM
hi francois,
thanks for your answer, for what reason ever i didn't receive a e-mail notification to your reply (maybe i forgot to check the checkbox).
i agree with you that the interaction between Rapid-PVST+ and MST is not handled with priority - our case is only a temporay workaround.
anyhow, in the meanwhile i've already answered the qustion:
yes, the interaction between the CIST and the "outside" RPVST+ domain works in rapid-fashion.
we implemented the hybrid solution at customer side and it works fine.
if you don't forget to enable "portfast" on the user ports of the RPVST+ Cloud (and therefore run into the holdtime of 15sec), the switchover is as rapid assumed.
kind regards,
bernhard
06-22-2015 04:21 AM
Hello Francois,
To change rapid-pvst+ topology in a Cisco infrastructure for a MSTP topology, I suppose I can change the MSTP on the L3 equipment first and then on the others. But I don't know if this is the right procedure or if all the equipments should be changed simultaneously.
Could you help me with this?
Thank you very much.
