Rapidly increasing "Total output drops" counter on a 6513
One of two 6513's increases the counter on ALL RJ45 ports of a 48-Port RJ45 FE Module, no matter if a cable is connected or not. About 20'000 - 30'000 drops per second ! VLAN membership independent. Other modules like GBIC-Blades are well, but not this FastEthernet module. CPU and interface load are little.
May we have a hardware problem on this module? Defect buffer memory ?
Here's a port config ex:
interface FastEthernet9/12
no ip address
switchport
switchport access vlan 2
switchport mode access
c6513-rz1-1#show interfaces fastEthernet 9/12
FastEthernet9/12 is up, line protocol is up
Hardware is C6k 100Mb 802.3, address is 0001.63d6.3e4d (bia
0001.63d6.3e4d)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Full-duplex, 100Mb/s
Last input never, output 00:00:06, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops:41585838
Queueing strategy: fifo
Output queue :0/40 (size/max)
37627906 packets input, 4622192613 bytes, 0 no buffer
Received 76970 broadcasts, 0 runts, 0 giants, 0 throttles
2706267307 packets output, 1116158169191 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
0 lost carrier, 0 no carrier
Any suggestions or ideas will be great
Thanks and regards Peter
1 REPLY
Re: Rapidly increasing "Total output drops" counter on a 6513
Hi Peter,
The FE module is faulty. As a test try swapping this FE module into the 2nd 6513 and see if the behaviour continues to confirm the problem lies with the module.
Find URL on output queue drops :http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a0080094791.shtml suggesting this.
The section called Note under Output Queue Drops in the article describes a situation that fits the problem you 've described.
Here is what the note says below:
Note: There is one exception - if the output queue is constantly full and if no packets are being sent out of the interface at all, then it may be an indication of a hardware failure on the interface
Victor
140
