RAS using isdn PRI/BRI on 3662
I have one 3662 router with one isdn pri and 4 isdn bri connections .Can i use these isdns for setting ras , while the remote user uses a analog line .
Do i require some additional hardware card on router ?
what is the configurations?
Bronze
Re: RAS using isdn PRI/BRI on 3662
YES.. you need to have a digital model module along with those isdn lines. Those digital modem modules are mica modems with part number NM-6DM which has 6 mica modems. So based on simultaneous analog connections required, you need that many modems.
Here is the url for configuring 3600 routers using T1/PRI line and mica modems
http://www.cisco.com/warp/public/793/access_dial/t1_dialin_5412.html
Configuring Modem Connectivity with a Cisco 3640 BRI
http://www.cisco.com/warp/public/471/bri_3640.html
Just combine bri and pri config togather.
160
