Webcast-Catalyst9k
Rate Limit problem
the goal is to provide my customers bandwidth 128kbps shared by two.
so for that i have applied a CAR rate limit to an ATM subinterface under which i have configured multiple PVCs to terminate PPPoE Tunnels .
but it seems , and referring to outputs of " sho inter rate-limit" that the rate limit is not working.
the Cisco device used is 7206 VXR ( NPE 400) and IOS used is:
c7200-jo3s-mz.122-4.b5.bin.
Here are the Interface config and the ouptuts od sho inter rate:
interface ATM4/0.11 multipoint
rate-limit input 720000 90112 90112 conform-action transmit exceed-action drop
rate-limit output 720000 90112 90112 conform-action transmit exceed-action drop
pvc name_dsl 3/xxx
ubr 128
encapsulation aal5snap
protocol pppoe
pvc fast_dsl 3/yyy
ubr 128
protocol pppoe
pvc sky_dsl 3/zzz
ubr 256
protocol pppoe
pvc name2_dsl 3/xyz
ubr 128
protocol pppoe
pvc name3_dsl 3/yxz
ubr 256
protocol pppoe
pvc name4_dsl 3/zyx
ubr 128
protocol pppoe
router#sho inter atm4/0.11 r
router#sho inter atm4/0.11 rate-limit
ATM4/0.11 DSL-128:2
Input
matches: all traffic
params: 720000 bps, 90112 limit, 90112 extended limit
conformed 0 packets, 0 bytes; action: transmit
exceeded 0 packets, 0 bytes; action: drop
last packet: 65584036ms ago, current burst: 0 bytes
last cleared 18:12:56 ago, conformed 0 bps, exceeded 0 bps
Output
last cleared 18:12:56 ago, conformed 0 bps, exceeded 0 bps.
any insight on this ? this is critical to me because i am using rate limit in order to allocate bandwidth to my DSL users .
anothe question :Is there another scientifical and accurate way to share bandwidth in the order 128:2.
i hope that i was clear in my description and sorry fot this long story.
Thanks and Best Regards,
Ali
1 REPLY
Re: Rate Limit problem
I guess this has got something to do with a standard bug on this image, not sure though...
103
