Community Member
Rate limiting an Interface with Subinterfaces
I need to impose a rate limitation across an entire ATM interface so that all of the subinterfaces share the available bandwidth. The subinterfaces each have a PVC associated with them and the interface itself has no PVC's or IP configuration.
Can I use the rate-limit command at the interface level to accomplish this?
Silver
Re: Rate limiting an Interface with Subinterfaces
Configure your ATM PVC's as VBR-NRT or VBR-RT. Then you can specify the peak speed in terms of Kbps that the PVC can operate at. Much easier and cleaner than rate-limiting.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121cgcr/wan_c/wcdatm.htm
Brad H.
Community Member
You can use per-vc CBWFQ to achieve that
http://www.cisco.com/warp/customer/121/7200_per-vc-CBWFQ.html
or you refer whole IP to ATM COS section of tech tips
http://www.cisco.com/warp/customer/121/#7
154
