Community Member
Rate Limiting for Catalyst 6509
Can I do rate limiting for Catalyst switch 6509?
Any support document that I can refer to?
Thank you for any reply
Community Member
Re: Rate Limiting for Catalyst 6509
yes you can do qos policing or if you running IOS you can do rate limiting. Both will do what you want except qos policing can only do Ingress i believe.
Community Member
yes. am running IOS.
any guide?
thanks!
103
