Webcast-Catalyst9k
rate limiting for ingress traffic in Cisco 2960 L2 Switch
We have a requirement to restrict the ingress bandwidth to 512 kbps on a fastethernet port in Cisco 2960 L2 switch. Would be helpful if somebody let me know at the earliest.
Blue
Re: rate limiting for ingress traffic in Cisco 2960 L2 Switch
you can perform ingress and egress bandwidth allocation on the 2960.
please see the following link for 2960 bandwidth configuration: (ingress)
http://www.cisco.com/en/US/products/ps6406/products_configuration_guide_chapter09186a00805a7699.html#wp1065146
Is there any way to restrict bandwidth as low as 256K on a fastethernet port on 2960?
Document says about restricting from a minimum of 1 Mbps and multiples of it.
Bronze
Hii raj,
the basic l2 switches can only police in multiples of 1 M, for minute limiting u will have to use higher l3 3500 switches or u can use a router with an l2 switch creating encapsulation.
pls do rate the post.
661
