rconsole problem with 2600
I have a Novell 3.12 server running on a network that runs off of one of the interfaces on a 2600 running version 12.1. When I try to run rconsole from another PC that runs on a network on the other interface I get a "SPXEstablishConnection failed" message. IPX and IP between the two interfaces work fine otherwise and this is the only problem. When I try to run rconsole on a PC that is resident on the same network as the Novell server I can get in.
Re: rconsole problem with 2600
Firstly check if the rconsloe service has been enabled on the server.
The other reason probably could be the helper address configuration.
Make sure you have configured the right addresses for the flooding of broadcasts.
Here's an eg:
Interface ether 0
ipx network 1000
ipx helper-address 1011.ffff.ffff.ffff
For details refer:
http://www.cisco.com/warp/public/458/32.html
I checked the server on the remote site and the rconsole service is running and it does work from the site. First I tried to to flood ipx using the 1.ffff.ffff.ffff as the helper list address method but that did work. Second I tried to specify the individual ipx interface node number in the ipx helper list but that also did not work
any help
92
