Community Member
read serial number of a 2611XM by CLI (online)
who is it possible to read the serial number of a 2611XM by CLI(online)
Processor board ID (sh ver) isn't the serial number
os the Router (here 2611XM) !!!
is there a undocumented command ?
any tips
r-e-g-a-r-d-s
VIP Purple
Re: read serial number of a 2611XM by CLI (online)
you cannot get the serial number from the command line, you have to physically look at the device.
GP
Community Member
I can't find serial number at
I can't find serial number at the device, in case in some device i can get the serial number from CLI but in another device i can't
Hall of Fame Super Blue
Depending on the IOS you are
Depending on the IOS you are using, you can check with the following commands:
1.  sh version; and
2.  sh inventory
Hall of Fame Super Gold
I am pretty sure that 2600 is
I am pretty sure that 2600 is old enough that the show inventory command does not work on it. If you use the command it may not return a value or it may return a value - but my experience is that value returned does not match the value on the label on the router.
rICK
398
