Community Member
Recomended max number of vrf is supported in Cat3550-48?
Mulit-VRF is supported in Cat3550-48. Could you advise the max number of vrf is supported? For example, each vrf contains around 200 routes.
Cliff
1 REPLY
Silver
Re: Recomended max number of vrf is supported in Cat3550-48?
Cliff,
I do not believe that there is a maximum number of VRF. I think you determine that by setting the max-threshold for the routes. You may need to check with Cisco to determine this.
93
