Recommended CatOS and IOS for Catalyst 4006 with SUP II
We have Catalyst 4006 switches each with following config :
WS-X4013 CatOS 6.1(2)
WS-X4232-L3 IOS 12.0(10)W5(18f)
WS-X4148-RJ
WS-X4306
I would like to know the recommended CatOS and IOS versions for the above configuration
Bronze
Re: Recommended CatOS and IOS for Catalyst 4006 with SUP II
Use the hardware/software compatibility matrix to determine what IOS and Cat OS supports your hardware configuration.
http://www.cisco.com/cgi-bin/front.x/Support/HWSWmatrix/hwswmatrix.cgi
Thanks raymong,
What i want it the latest stable releases for the said configuration. The matrix show the minimum required releases.
Parag
6.4(2) for Sup2 and 12.0(18)W5(22b) for RSM. However I suggest that you read the release notes for known issues/features
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/relnotes/index.htm
Thanks prkrishn,
We have just received one new 4006 which has 7.4(2) pre-installed on its sup-ii, while all my existing 4006 has 6.1(1) installed on thier sup -ii. Rest of the switch config. remains same.
I would like to have a uniform configuration of CatOS on all my 4006. Should i upgrade all of them to 7.4(2) or downgrade the new one to 6.4(2) as suggested.
Parag
276
