Recommended Configuration For UDLD Aggressive Mode
I have point-to-point links in my LAN between Distribution and Access layer switches and want to enable UniDirectional Link Detection (UDLD) aggressive mode.
Do I need to enable it on both ends or just one? If just one, should it be the Distribution or Access layer switch?
1 REPLY
Anonymous
N/A
Re: Recommended Configuration For UDLD Aggressive Mode
UDLD aggressive mode will only
work if enabled on both sides of
the connection. UDLD aggressive
mode is a highly-recommended
feature as it prevents Spanning Tree
Protocol (STP) problems and other
failures. All connections between
switches should have this feature
enabled.
110
