Community Member
Red light on Catalyst 4006
I have a red led light on a Catalyst 4006, supervisory 2 module. Any ideas how severe? And/or a fix?
1 REPLY
Re: Red light on Catalyst 4006
Check to see if all your 3 power supplies are plugged into a PS. If you have a power supply which is not plugged into a source, the status will be faulty. Do a "show system"
282
