Community Member
Redistribute static in OSPF and EIGRP
When use "redistribute static" in OSPF OR eigrp, does it also redistribute connected networks?
When use "sh ip eigrp topology", the entries with "via RStatic" indicate a redistribution of static routes, corret?
Purple
Re: Redistribute static in OSPF and EIGRP
"redistribute static" will NOT redistribute connected routes for either EIGRP or OSPF.
Entries with 'RStatic' are indeed routes that are injected into EIGRP via the redistribution of static routes.
Hope that helps - pls rate posts that are helpful.
Paresh
redistribute static will redistribute all static routes found in the IP routing table. In case you want to announce the connected interfaces you have two options:
1) router ospf 10
network 192.168.1.1 0.0.0.0 area 0
for
interface Ethernet0
2) router ospf 10
The same applies for EIGRP.
Hope this helps! Please rate all posts.
Martin
324
