11-18-2003 04:15 AM - edited 03-02-2019 11:47 AM
I'm running a couple of routers and using rip2 as the routing protocol and advertises the static routes with Redistribute static. But now I added a static route on one of the routers,
ip route 193.45.139.240 255.255.255.255 10.0.4.105
but when I check the routing tables on the other routers they've got
R 193.45.139.0/24 [120/1] via 10.0.5.2, 00:00:01, GigabitEthernet5
Why isn't the subnetmask advertised? Rip2 handles different subnetmasks all the other time.
Here is a pice of the running.config:
router rip
version 2
redistribute static
network 10.0.0.0
ip classless
ip route 0.0.0.0 0.0.0.0 10.5.1.31
ip route 194.22.190.13 255.255.255.255 10.5.1.60
ip route 195.198.127.34 255.255.255.255 10.5.1.60
ip http server
Solved! Go to Solution.
11-18-2003 06:12 AM
11-18-2003 04:17 AM
Try the command "redistribute static subnets" .
11-18-2003 05:30 AM
It dont reconize the option 'subnets'
Is it availiable for the Rip2-protocol?
11-18-2003 06:12 AM
router rip
no auto-summary
will fix it.
11-18-2003 09:45 PM
Yes, no auto-summary did it! Thanks
