redistribution between ospf and rip2
Hi All,
I am tring to mutual redistribute ospf and rip2 with tag, but it doesn't work. from RIP side I can see the ospf routes, but at ospf side I can't see any routes from RIP. Could someone figure out what's wrong in my configuration. Thanks a lot.
interface Loopback0
ip address 150.50.6.6 255.255.255.255
interface Ethernet0
ip address 150.50.100.6 255.255.255.0
interface Serial0
ip address 150.50.10.6 255.255.255.0
encapsulation frame-relay
ip ospf network point-to-point
frame-relay map ip 150.50.10.2 421 broadcast
frame-relay map ip 150.50.10.6 421
frame-relay lmi-type ansi
router ospf 1
log-adjacency-changes
redistribute rip subnets route-map rip-os
network 150.50.6.6 0.0.0.0 area 0
network 150.50.10.0 0.0.0.255 area 0
router rip
version 2
redistribute ospf 1 metric 1 route-map os-rip
passive-interface default
no passive-interface Ethernet0
network 150.50.0.0
route-map os-rip deny 10
match tag 120
route-map os-rip permit 20
set tag 110
route-map rip-os deny 10
match tag 110
route-map rip-os permit 20
set tag 120
Gold
Re: redistribution between ospf and rip2
You can't use the tags on the rip to ospf side--rip doesn't carry tags, so the result would probably be that no routes carry from rip into ospf. Second, you probably need a default metric on the ospf side, to carry from rip into ospf. This isn't always required, but it's always safe to put it in.
So, I'd try this:
route-map ospftorip deny 10
match tag 110
route-map ospftorip permit 20
route-map riptoospf permit 10
set tag 110
router rip
version 2
redistribute ospf 1 metric 1 route-map ospftorip
router ospf 1
network ....
redistribute rip subnet route-map riptoospf
default-metric 10
I can set up a sample config in the lab if this doesn't work, or you're still having problems.
Russ.W
Hi Russ,
Thanks for your reply. You solution is working.
But I have little bit confusing. Cause from Jeff Doyle's Routing TCP/IP Volume 1, it say RIP v2 does support route tag.
BTW, which version ios you use in your lab.
Banlan
Gold
Hmm.... RIPv2 does support tags--it's in the protocol extensions section of 2453. So, I went to the code to see if Cisco supports this, and it looks like we do.
So, then, I went to the lab, and checked, and I see that you can set and filter based on the tags in rip:
On the first router:
router rip
version 2
redistribute connected route-map testtag
network 208.0.7.0
default-metric 10
no auto-summary
route-map testtag permit 10
set tag 100
2651A#sho ip rip data
208.0.0.0/24 auto-summary
208.0.0.0/24 redistributed
[1] via 0.0.0.0,
208.0.7.0/24 auto-summary
208.0.7.0/24 directly connected, Serial0/0
On the second:
router eigrp 100
redistribute rip route-map testtag
network 208.0.6.0
default-metric 1000 1 255 1 1500
auto-summary
router rip
version 2
network 208.0.7.0
no auto-summary
match tag 100
route-map testtag deny 20
7206F#sho ip eigrp topo
IP-EIGRP Topology Table for AS(100)/ID(208.0.10.4)
Codes: P - Passive, A - Active, U - Update, Q - Query, R - Reply,
r - reply Status, s - sia Status
P 208.0.0.0/24, 1 successors, FD is 2560256, tag is 100
via Redistributed (2560256/0)
P 208.0.6.0/24, 1 successors, FD is 281600
via Connected, Ethernet1/2
Note the tag in the eigrp table entry for the 208.0.0.0 network.
So, that means that you should be able to do this, and something else is wrong with your configs above. They look okay except for the missing default metric under ospf, so maybe that's the main problem, not the tags.
Could you try it with the default metric command under router ospf, and see if that works?
Check the routing table on your rip routes, and see if the tag is set there, on the receiving router, without the redsitribution. And make certain any intervening routers are set up right for this, as well.
It might well be the IOS version, I'm on 12.2T in my lab, throughout, so.... It might be that these tags were carried, but not supported for filtering, until the rip database work was done, which was only about a year or 18 months ago, I think. I'd have to go look--rip isn't a protocol I keep up with too much (obviously).
Russ.W
Hi Russ,
It seems an IOS problem. I change to another router which is running 12.1(16) C2500-I-L, it's working. My previous one is 12.2(1d) C2500-JK8OS-L.
I am trying to find a best way to do mutual redistribution, could you refer me some good links. Real appreciate your help.
Banlan
Gold
It is very possible that some versions will not require the default metric to work--did you try with a metric on the 12.2 version? It could also be a bug in the code (sorry, undoc'd feature, if you're talking to an SE). :-)
Anyway, it sounds like you have the config down. I don't have any real good tech tips or links into stuff on mutual redistribution. There are some slides in the eigrp networkers presentation for the last couple of years that talks about this in terms of EIGRP only, and there are some slides in the igp power session from this year's networkers.
There'll be a good solid section in the rewrite of Advanced IP Network Design (just under way, should be published june of 2004 or so, I think). There's some int he current edition of Advanced IP Network Design, but I don't recall how much. I can also put a tech tip on this on my list of things to do.
But of course none of that is going to help you right at the moment. :-( If you email me, I can poke around some more, and see what I can find in the way of stuff to point you to.
Russ.W
248
