02-17-2003 07:31 AM - edited 03-02-2019 05:08 AM
hello everyone,
i encountered a unexpected behavior while working with redistribution from ospf to eigrp and route-maps.
what i am doing is setting the metric for individual networks in the route-map and not in the redistribute-command:
router eigrp 137
redistribute ospf 1 route-map o2e
network 172.21.9.0 0.0.0.255
and the route-map:
route-map o2e permit 20
match ip address 21
set metric 100 10 255 1 1500
the redistribution works fine after a reboot or after a clear ip route *. without any of the two no routes get redistributed from ospf to eigrp.
is this the normal behavior? does it have something to do with the recompiling of route-maps? can someone confirm this? or is it a bug?
i have tested it with 12.1(16), 12.1(18), 12.2(13a) on cisco2600 and cisco3600, they all show the same behavior.
thanks
/birgit
02-17-2003 07:06 PM
it's not normal.
Redistribution works fine without reboot or cle ip route *.
Wait a moment until routes get.
Try again.
02-18-2003 12:51 AM
hi,
thanks a lot for your answer. waiting doesnt change anything. the only message i get is this:
router#sh clock
*16:40:40.424 UTC Fri Mar 5 1993
router#conf t
Enter configuration commands, one per line. End with CNTL/Z.
router(config)#router eigrp 137
router(config-router)# redistribute ospf 1 route-map o2e
4d16h: IP-EIGRP: Callback: redistribute command ospf Sense: 1^Z
router#
4d16h: %SYS-5-CONFIG_I: Configured from console by vty0 (192.168.97.194)
router#
router#
router#sh clock
*16:45:00.672 UTC Fri Mar 5 1993
router#sh clock
*16:49:57.932 UTC Fri Mar 5 1993
router#clear ip route *
router#
4d16h: IP-EIGRP: Callback: redist frm ospf AS 1 192.168.97.68/30
4d16h: into: eigrp AS 137 event: 1
4d16h: IP-EIGRP: Callback: redist frm ospf AS 1 172.21.5.5/32
so i guess i will open a case.
thanks
\birgit
02-18-2003 01:02 AM
Hi Birgit
I just checked this on my routers and i had the same behavior. If i give the metric along with the redistribution it works fine as soon as i set the metric in the route-map the route will not be redistributed till you do the clear ip route*. So for me it also looks like a bug.
Roger
02-18-2003 02:22 AM
hi roger,
just opened a case with a company you are related closely to ;)
thanks
/birgit
