Webcast-Catalyst9k
Reduce Ethernet Bandwidth
I have a trio of ethernet interface of 10 Mbps. I want to reduce it to about 1 Mbps for all traffic. That is, reduce the capability of 10 Mbps ethernet to the level of T1 (1.544 Mbps). I know it sounds strange, but I want to test something that needs slower speed. Is there a way to do it on the software side. If not, then which hardware I should put over there.
1 REPLY
Re: Reduce Ethernet Bandwidth
You can create 1 or some VLAN and apply a rate limit
on it
jd
133
