Redundancy and Load Balancing
Hi.
I have 02 routers Cisco 2610XM and 01 switch Catalyst 3550 (vide attachment) and I need a help to implement a redundancy and load balancing in my environment using my switch.
What I have to do? Some friends told me that I can use HSRP but it doesn´t work...
Thanks.
Re: Redundancy and Load Balancing
By implementing HSRP on the two routers you can provide a redundant default gateway for your client. If one router (active) fails the other router (backup) takes over.
Follow the steps in this whitepaper for implementing HSRP
http://www.cisco.com/en/US/products/ps6600/products_white_paper09186a00804fab8f.shtml
Let me know how you get on.
Sarb
Sarb,
Thank you very much for your reply.
My environment has changed since my question. Now, I have 2 switches Catalyst3550 and 2 routers 2610XM (vide attachment)
To implement the HSRP in my environment, I have configured the layer3 in the switches and configuration is the following:
Switch01
interface vlan1
ip address 10.150.21.3 255.255.255.0
standby 1 ip 10.150.21.5
standby 1 priority 110
standby 1 preempt
standby 1 track vlan1
ip route 10.150.1.0 255.255.255.0 10.150.21.2
ip route 172.16.62.44 255.255.255.252 10.150.21.253
ip route 172.16.62.48 255.255.255.252 10.150.21.254
Switch02
interface vlan1
ip address 10.150.21.4 255.255.255.0
standby 1 priority 105
standby 1 preempt
ip route 10.150.1.0 255.255.255.0 10.150.21.3
ip route 172.16.62.48 255.255.255.252 10.150.21.253
My firewall is using as gateway the IP 10.150.21.5.In the routers I have added just the static routes from my Lan. I need to change something in my routers?
Another question... Just using static routes can I have load balancing?
Rodnei
191
