Redundant Link between 3500 switches
We have a host of 3548's\3524s connected to 3508 via GBIC Fibre.
We are trying to incorporate some redundancy in our solution for a link
failure. We have spare copper ports on the 3524 which connects to the
servers and wanted to use these ports to connect to each3548 has a
redundant link which is blocked by Spanning tree and invoked in a loss
of fibre to a switch. Would we experience any problems with implementing
this?
Mark
Our other thought was to cascade copper from the 3524 to a 3548 and then
from that 3548 to the next and so on.
Re: Redundant Link between 3500 switches
You can do both, either in chain-like 1-2-3-4-1 or like star with dual links.. and since this is 100MB link, the spanning should automatically block the 100Mb link and forward on 1G link. Make sure you make the main, core switch as the root of the spanning tree.
Here are some good doc. on spanning tree for your ref.
http://www.cisco.com/cgi-bin/Support/browse/psp_view.pl?p=Hardware:Cat2900-XL&s=Software_Configuration#Software_Samples_and_Tips
A starshaped toplogy is to be preferred over cascading numerous switches.
For redundancy you might consider grouping the two ports into etherchannels. This will add load-balancing to the redundancy.
This can be implemented without much trouble.
Etherchannels cannot be formed with links of different speeds. (A 100mb link cannot be grouped with a 1000mb link & so on..)
138
