Webcast-Catalyst9k
redundant link-design for catalyst 4500
hi, i have an existing catalyst 4506 and im planning to buy another core switch and link it to my 4506. is it possible for the two core switch to have a fail-over redundant link and load balancing? if yes how will i link the two switches and my access switches using fiber. can somebody help me,thanks
1 REPLY
Re: redundant link-design for catalyst 4500
you can do channel configuration between you 4500s. This provides you both redundancy and load-balancing.
http://www.cisco.com/en/US/products/hw/switches/ps4324/products_configuration_guide_chapter09186a00801c6242.html
hope this helps..
112
