Community Member
Redundant Sup 1A causing problems
Folks,
We should ordered a second sup for our Catalyst 6500. CCO doc. says that as soon as I plug the second sup in the chassis the primary chassis should duplicate the Code image ( Catos) and configuration file to the secondary sup.
It did not happen in my case, i kept getting sync errors.
Anyways i manually copied the code and the configuration file to the flash of the second sup, what else should i do for the redundancy to work, i configured high availability on the switch as well???
Re: Redundant Sup 1A causing problems
Did you had High avialablity versioning enable on you active sup. If yes then while you have versioning enable it doesnot copy the code to the the standby sup.
Do a show high-availabuility on your system and it will show you if versioning is enable.
If you have that enable do " set high-availability versioning disable " and it will copy the code to your second sup.
HTH,
-amit singh
Community Member
amit,
Thanks for the response. High availability was turned off when i put the secondary sup inside the chassis. I am using external flash by the way for code and configuration file, It did give an error about syncing something.
The i turned on high availability without the versioning feature, but got the same results.
Is it because i am using external flash to store all this information.
Also the prepend option does not show up in the config ether, how would the seconday sup know what file to boot from when it comes online??
Cisco Systems Console
Enter password:
DawnCore1-6509> en
Enter password:
DawnCore1-6509> (enable) show conf
This command shows non-default configurations only.
Use 'show config all' to show both default and non-default configurations.
begin
# ***** NON-DEFAULT CONFIGURATION *****
#time: Mon Sep 26 2005, 00:46:34
#version 7.6(1)
set password $2$loO/$6pP1tokFdiW0EKXp.4QPD0
set enablepass $2$3zKC$v8lDJFRwrMxd/Kz8C3eDT/
#errordetection
set errordetection portcounter enable
#system
set system name DawnCore1-6509
set system highavailability enable
#vtp
set vtp domain Joy
set vlan 1 name default type ethernet mtu 1500 said 100001 state active
set vlan 3 name CANco-L3 type ethernet mtu 1500 said 100003 state active
set vlan 50 name BlueSky type ethernet mtu 1500 said 100050 state active
set vlan 51 name Trestle type ethernet mtu 1500 said 100051 state active
set vlan 52 name PumpHouse type ethernet mtu 1500 said 100052 state active
set vlan 53 name Printer-VLAN type ethernet mtu 1500 said 100053 state active
set vlan 100 name Servers type ethernet mtu 1500 said 100100 state active
ve mode srb aremaxhop 0 stemaxhop 0 backupcrf off
#ip
set interface sc0 100 192.168.0.12/255.255.255.0 192.168.0.255
set interface sc1 0 0.0.0.0/0.0.0.0 0.0.0.0
set interface sc1 down
set ip route 0.0.0.0/0.0.0.0 192.168.0.6
set ip alias default 0.0.0.0
#spantree
#vlan
set spantree priority 8192 100
set spantree priority 8192 900
#syslog
set logging level ethc 2 default
set logging level gl2pt 2 default
#set boot command
set boot config-register 0x2
set boot config-register auto-config sync enable
set boot system flash slot0:cat6000-supk8.7-6-1.bin
set boot system flash bootflash:cat6000-sup.5-5-1.bin
set boot system flash bootflash:cat6000-sup.6-1-2.bin
#igmp
set igmp disable
#qos
set qos wrr 2q2t 5 255
set qos wrr 1p2q2t 5 255
set qos wred 1p2q2t tx queue 1 40:80 70:100
set qos wred 1p2q2t tx queue 2 40:80 70:100
set qos wrr 1p2q1t 5 255
# default port status is enable
#module 1 : 2-port 1000BaseX Supervisor
set spantree portfast 1/1-2 disable
set spantree guard none 1/1-2
#module 2 : 2-port 1000BaseX Supervisor
#module 3 empty
#module 4 : 48-port 10/100/1000BaseT Ethernet
set vlan 100 4/1-32,4/37-44,4/46,4/48
set vlan 121 4/33-36,4/47
set vlan 900 4/45
set port speed 4/45 100
set port speed 4/33-35 1000
set port duplex 4/45 full
set port name 4/45 Can Co. - Balticore
set port name 4/47 Dawn Phone Port
#module 5 empty
#module 6 empty
#module 15 : 1-port Multilayer Switch Feature Card
#module 16 : 1-port Multilayer Switch Feature Card
end
DawnCore1-6509> (enable) show system highavailability
Highavailability: enabled
Highavailability versioning: disabled
Highavailability Operational-status: ON
Paresh,
It will not sync the image files which are in PCMCIA slot i.e file on external flash. That's why your flash didnot synchronize.
Now there are 2 types of image syncronization on the Supervisors, it will never show you with prepend keyword.
1. Image name preceded by RT_SYNC on standby sup i.e runtime sync which means that you have an active sup running on the box and you inserted another one and that's the run time sync.
2. Image name preceded by BT_SYNC on standby sup i.e Boottime sync which means that you have an active sup and standby sup running on the box and you have upgraded the OS on the active one and it synchronize its flash code with the standby one.
These image codes will only be see on the standby sup after the code sync.
HTH,
-amit singh
Community Member
Amit,
Here is the output from my 6500. Can you please tell me why the Code did not syncronize on my bootflashes???? Also what should i do since my running code and configuration file is on external flash now to make sure that the seconday boot correctly when the primary goes down.
#set boot command
DawnCore1-6509> (enable) show flash bootflash:
-#- ED --type-- --crc--- -seek-- nlen -length- -----date/time------ name
1 .. ffffffff eb09dc06 812780 28 8201983 Apr 14 2001 06:42:06 BTSYNC_cat60
00-sup.6-1-2.bin
7788672 bytes available (8202112 bytes used)
DawnCore1-6509> (enable) show flash 2/bootflash:
1 .. ffffffff c4251471 a1d9d4 30 10344787 Sep 24 2005 10:03:23 RTSYNC_cat60
00-supk8.7-6-1.bin
5645868 bytes available (10344916 bytes used)
DawnCore1-6509> (enable) show flash slot0:
1 .. ffffffff fbb43e32 20804 4 1921 May 10 2004 17:45:20 6509
2 .. ffffffff c4251471 9fe1d8 23 10344787 May 10 2004 18:38:56 cat6000-supk
8.7-6-1.bin
14425640 bytes available (10346968 bytes used)
DawnCore1-6509> (enable) show flash 2/slot0:
1 .. ffffffff c4251471 9fd9d4 23 10344787 Sep 24 2005 10:55:14 cat6000-supk
8.7-6-1.bin
14427692 bytes available (10344916 bytes used)
DawnCore1-6509> (enable)that the standby sup boots correctly when primary goes down?
Paresh,
Please paste a show mod / show version from your switch. I think you want to upgrade to 7.6.1. Which one is ur active sup ? is it the one with 7.6.1 code.. if yes then it will not sync teh code to the other one as the other sup doesnot have enough spance n bootflash to accomodate the new cat OS. so this is related to flash memeory problem. Check the difference in memory space on both the sup's flash. If you dont have enough space it will not sync the bootflashes. And again the images on Slot0 will not be synchronize.
HTH,
-amit singh
Community Member
I manually pasted the code to flash slot0 of redundant sup. how can i copy the running congiguration to the redundant sup???? do you know what is the file naming convetion?
Community Member
Can i erase the bootflash of the seconday sup?? what is the command?
You can erase the image on secondry sup using the command
delete 2/image_name
squeeze 2/bootflash:
You can also format the bootflash using the format command.
By default, the active sup synchronizes the config with standby sup. So it must be having the config. If you want to take a back up or want to manually copy the config use the follwing comamnd :
copy config slot0:
copy config bootflash:, normally we use .cfg format.
ex. switch.cfg
regards,
-amit singh
173
