Redundant switching with two 2950's
young.andrew
Ive been reading up on STP and only see examples of network configurations with more than 3 swithces. I am trying to achieve redundancy using two 2950's. Is this possible? In front of the 2950 would be a pair of PIX 515E's in Active/Failover configuration. Could someone give me a hint to put me on the right path? Thanks ahead of time.
smahbub
Level 6
Level 6
Do you mean configuring vlan load balancing using STP port priority.
Here is a good link:
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a0080
0ae96a.shtml.
This document explains clearly regarding the VLAN Load Balancing Between Trunks Using the Spanning-Tree Protocol Port Priority.
If u dont find solution with this link,let me know.But elaborate ur requirement a little bit.
winslowtravis
I believe EtherChannel may be what you are looking for. Do a search for it and it should explain all the details.
