Community Member
redundency and load balancing
Is it possible to install two ADSL WICs in a Cisco 1841 or 2800 router and configure them for redundency and load balancing? If so please send me a sample configuration.
1 REPLY
VIP Purple
Re: redundency and load balancing
the easiest way to configure outbound load balancing would be to create two equal-cost static default routes, the router configuration would look like this:
interface ATM0/0/0
no ip address
no ip route-cache
no ip mroute-cache
no atm ilmi-keepalive
dsl operating-mode auto
pvc 1/33
encapsulation aal5snap
pppoe-client dial-pool-number 1
interface ATM1/0/0
no ip address
no ip route-cache
no ip mroute-cache
pvc 1/35
pppoe-client dial-pool-number 2
interface Dialer1
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer pool 1
dialer-group 1
interface Dialer2
ip mtu 1452
ip nat outside
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer pool 2
dialer-group 1
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 0.0.0.0 0.0.0.0 Dialer2
Can you try and see if this works for you ?
The config above does not include any CHAP or PAP, obviously you will probably need to have to add that. Let me know if you run into trouble...
HTH,
GP
158
