Regarding 7206vxr routre
                   HI , can anyone tell how many Gigabit port will be supported by Cisco 7206VXR with G1 engine model. By deault we hot 3 GE, is it possible to add additional Gigabit ports with the existing hardware. Please clarify.
Everyone's tags (1)
Hall of Fame Super Gold
You can add a PA-GE, but it will not have good performances like the embedded itnerfaces, so it's not advisable to do that.
Hi paolo, thanks for the reply, I need some more clarification, Apart from 3 embeded GE ports, how many we can add if we want. In case if we add how it will degrade the performance or any cause bcz of that.
Gold
You will need to work through the details based on bandwidth
see the link below.:
http://www.cisco.com/en/US/docs/routers/7200/configuration/7200_port_adapter_config_guidelines/3875In.html
If you need that much gigabit, I would suggest a better router.Based on my own experience effective throughput on a Gig interface tops out around 800Mb.
294
