04-08-2016 02:25 AM - edited 03-03-2019 08:11 AM
I’m writing to about temperature issue.
The thing is, High temperatures are dangerous.
But, I don't know danger temperature zone.
Hence, Is there the cisco set up a standard about the temperature value?
for example, 70oc -> critical, 100oc -> need to rma
plesae refer to below log.
module 9 asic-1 temperature: 63C module 9 asic-2 temperature: 59C
Solved! Go to Solution.
04-08-2016 03:53 AM
"show environment alarm thresholds module 9" should show you the minor and major threshold values for the temperature sensors on that line card
04-12-2016 02:05 AM
thats the temp specification the room should be running in between to have the device operating normally at proper temps , where the device is stored basically , these are recommendations , you will see nearly all data sheets have a max of 70 degrees but then can vary how cold the room can be too some as low as 40 or 20
04-08-2016 03:13 AM
if you check your modules data sheet online you will see they have guidelines for the temp to be ran at , 63 is high you may need more air conditioning in room /ventilation
Diff modules can vary though so always best to check the sheet for esach type but generally you want to be below 50%
As an example I just checked a few 6500s I have here and there all below 50% and within the range expected for my module 6748
module 2:
module 2 power-output-fail: OK
module 2 outlet temperature: 34C
module 2 inlet temperature: 30C
module 2 device-1 temperature: 34C
module 2 device-2 temperature: 31C
module 3:
module 3 power-output-fail: OK
module 3 outlet temperature: 38C
module 3 inlet temperature: 26C
module 4:
module 4 power-output-fail: OK
module 4 outlet temperature: 32C
module 4 inlet temperature: 28C
module 4 device-1 temperature: 37C
module 4 device-2 temperature: 29C
module 5:
module 5 power-output-fail: OK
module 5 outlet temperature: 33C
module 5 inlet temperature: 29C
module 5 device-1 temperature: 38C
module 5 device-2 temperature: 31C
module 7:
module 7 power-output-fail: OK
module 7 outlet temperature: 29C
module 7 inlet temperature: 24C
module 7 device-1 temperature: 32C
module 7 device-2 temperature: 33C
module 7 asic-1 temperature: 25C
module 7 asic-2 temperature: 25C
module 7 asic-3 temperature: 25C
module 7 asic-4 temperature: 25C
module 7 asic-5 temperature: 25C
module 7 asic-6 temperature: 25C
● Operating temperature: 32 to 104°F (0 to 40°C)
● Storage temperature: –40 to 167°F (–40 to 75°C)
● Relative humidity: 10 to 90 percent, noncondensing
● Operating altitude: –197 to 9843 ft (–60 to 3000m)
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-6500-series-switches/product_data_sheet0900aecd8017376e.html
04-10-2016 06:42 PM
Thank you for your reply.
If this issue is unrelated to aircon, What should i check? (this means that air condition has already installed)
04-11-2016 12:35 AM
Make sure none of the rack panels where the fans are on the chassis are obstructing the airflow if the temp in the room is ok or that no other device is blocking airflow
Make sure no other devices are seeing same issue that way it will isolate it to just the chassis , turn up the aircon if possible see if it makes a difference over a day
04-12-2016 01:26 AM
Thank you for your assistance.
I have a last question..
04-12-2016 02:05 AM
04-08-2016 03:53 AM
04-10-2016 06:43 PM
I'll get it checked soon.
