11-12-2003 03:16 PM - edited 03-02-2019 11:40 AM
I´m having some problems giving Internet access to my remote users via a Cisco 2621 with 16 async ports, I have no modem or authentication issues, the problem is that once they access the local network they can´t reach the Internet,
We´re only using the router as an access server and going to the internet via a squid proxy server (port 3128) and an IP 10.254.15.18
Is missing something in my configuration?:
version 12.0
service timestamps debug uptime
service timestamps log uptime
hostname RAS
username service password 0 service
memory-size iomem 20
ip subnet-zero
interface Ethernet0/0
ip address 10.10.1.1 255.255.0.0
no ip directed-broadcast
interface Serial0/0
no ip address
no ip mroute-cache
shutdown
interface Async33
ip unnumbered Ethernet0/0
encapsulation ppp
async mode dedicated
peer default ip address pool default
ppp authentication chap
ip local pool default 10.10.0.21 10.10.0.36
ip classless
line con 0
exec-timeout 0 0
transport input none
line 33
password Tele2
login local
modem InOut
modem autoconfigure type usr_sportster
transport input all
stopbits 1
speed 115200
flowcontrol hardware
no scheduler allocate
end
I really appreciate your feedback
Joe
11-12-2003 07:40 PM
I think you need a default route pointing to the next hop eg
ip route 0.0.0.0 0.0.0.0
11-13-2003 09:51 AM
I´ve already try this one:
ip route 0.0.0.0 0.0.0.0 Ethernet0/0
and:
ip default-gateway 10.10.0.254
and the problem persists, I dont know if I need to enable any routing protocol, if this is correct it´d be in the ethernet 0/1, right? for the other hand, Should I consider the proxy as the next hop?
Thanks in advance...
11-13-2003 12:23 PM
Use a default route pointing to your Proxy's IP.
"ip route 0.0.0.0 0.0.0.0 (Proxy IP)"
Then just make sure the Proxy is set up right (NAT, etc)
Daniel
