Remote management of Cisco 831
The Cisco 831 has the capibility of remote management but it appears to me that this only applies to the CLI. When I attempted to browse into the 831 I was prompted for a username/password, which I gave, then was prompted for a firewall username/password, which I had not setup in the 831. At this point I selected no and it appeared that I was just 'looping' getting no where.
Question - Should I be able to browse into the 831 without a firewall?
The reasoning for my inquires is that we are going to deploy some 831's to replace Cisco 3002 Hardware clients in the field and I was wanting to see what kind of remote capibilities I would have. The 3002 do not support the IP phones very well due to the lack of QoS and the 831 do.
Bronze
Re: Remote management of Cisco 831
I am not sure whether you are using the CRWS tool to manage the router. If so, this link has some information on troubleshooting using this tool. Check it out :
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_fix/831/hwins/install.htm#89434
Thanks, I had already read that information. What I was looking for was information on remote managing the 831 via the internet.
77
