Remote shell in CatOS
In IOS, it is possible to get the router or switch to perform remote shell commands by configuring the appropriate ip rcmd commands. Is it possible to do the same thing in CatOS?
Kevin Dorrell
Luxembourg
1 ACCEPTED SOLUTION
Re: Remote shell in CatOS
Kevin,
I'm not sure I understand your question. It is certainly possible to configure the router to respond to rsh commands coming from remote hosts. You need to configure the following:
ip rcmd rsh-enabled.
I do not think CatOS supports rsh.
Let me know if I understood you correctly,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Kevin,
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Harold,
Yes, you did understand correctly. I wanted to run a script to interrogate several parts of my network by using rsh to the various switches and routers. But as you say, the CatOS switches seem not to support rsh.
Thanks.
Kevin
125
