Community Member
Remote sites to balance with RIPv2 protocol
I have some sites which advertise the networks with RIPv2 to the backbone network.
There are 2 backbone routers to collect these sites.
Backbone routers are running BGP with other backbone routers.
I would like to balance the sites on both backbone collect routers.
Each remote site has got 2 CVP FR connections (DLCI 100 and 200)to these collect routers.
So I plan to configure for example
site1#
router rip
offset-list 0 in 5 Serial0/0.200
offset-list 0 out 5 Serial0/0.200
site2#
router rip
offset-list 0 in 5 Serial0/0.100
offset-list 0 out 5 Serial0/0.100
Is there another method , I would like to use the tags but are they advertised through RIP updates ? And a route-map is necessary on the sites to set the tags, isn't it ?
Thanks in advance
1 REPLY
Community Member
Re: Remote sites to balance with RIPv2 protocol
I have moved the question into the WAN routing part.Regards
68
