Webcast-Catalyst9k
Removing an interface
All:
I've disco'ed an unused T1.
I've issued a shut command on the interface.
How do I remove the interface from the config so that I don't have to look at it anymore?
tia
S
VIP Purple
Re: Removing an interface
there is no way to do that, you cannot remove a physical interface from the configuration, unless you use an IOS version that does not recognize the interface. Only logical interfaces (e.g. loopback or subinterfaces) can be removed from the config.
GP
Thanks ... I was unclear. I don't want to remove the interface itself, I just don't want to see the description and other items in the configuration when the interface supported a particular network.
What I want is to merely clean up my configuration file.
tia
S
in config mode see the DEFAULT command
Marco
h'mmm ...
config t
default int s1/1:0
interface returned to default,
Just what I needed.
thanks much
rgds
S
135
