Removing vdm from flash
Hello all,
Might be a stupid question but I am trying to remove vdm from flash so that I can try the qdm files and I have done what the directions say but it is still showing up when I do a show system flash it show up like vdm.tar (deleted). I have rebooted several times but have yet but no results. I have tried to do erase but with that command you have to do the whole flash module which I defiantly don't want to do.
David
1 ACCEPTED SOLUTION
Silver
Re: Removing vdm from flash
David,
Try "squeeze flash:" this will remove deleted files and allow you to recoupe the space without messing with other files that have not been deleted.
Hope this helps,
Don
Silver
David,
Hope this helps,
Don
squeeze flash:
Squeeze operation may take a while. Continue? [confirm]
first create squeeze log by erasing the entire device
%Error squeezing flash ()
I guessing that I am out of luck
Silver
Interesting... You might just nuke the whole filesystem (format/erase flash:) and copy on there the image you want via tftp. I am unsure why you're getting this error if the switch let you delete the file you spoke of in your previous post.
Hope this helps,
Don
101
