Community Member
reserved B-channels with PRI and rotary-group
I have a 2600 router with ISDN PRI and 1 serial Interface. Approx. 150 Clients are connecting to the PRI. In case of a serial link failure there should be ISDN-Backup (2 B-Channels) over the same PRI the Clients are connecting to.
Is there a possibility to configure a rotary-group but give the 2 B-Channels (needed for backing up the serial line) priority over the others? Like if all 30 channels are in use by some clients to drop 2 channels and use them for the backup.
With dialer-profiles I could reserve 2 channels for the backup but I want to avoid configuring 150 dialer-interfaces.
1 REPLY
Anonymous
N/A
Re: reserved B-channels with PRI and rotary-group
There is no way to prioritize dialer
maps that will cause existing connections
to be torn down. The best that I can
suggest is you try the command ,
which will cause the fast-idle timer to be
used instead of the idle-timer in the
event that all links are used and we need
to dial out to a new site. If the existing links
still have interesting data, you may not
see a disconnect right away. You could set the
fast-idle to a low value (like 5), but
beware that this may cause more than just
2 links to drop.
90
