reset problem on 6509 catalyst switch
Reset is require sometimes on WS-X6K-SUP2-2GE what could be the possible reasons.....
sh ver :-----
WS-C6509 Software, Version NmpSW: 6.1(1d)
Copyright (c) 1995-2001 by Cisco Systems
NMP S/W compiled on Jan 10 2001, 20:40:46
System Bootstrap Version: 6.1(3)
Hardware Version: 2.0 Model: WS-C6509 Serial #: SCA052701R0
Mod Port Model Serial # Versions
1 2 WS-X6K-SUP2-2GE SAD052003KT Hw : 2.2
Fw : 6.1(3)
Fw1: 6.1(3)
Sw : 6.1(1d)
Sw1: 6.1(1d)
WS-F6K-PFC2 SAD052103DK Hw : 1.4
2 2 WS-X6K-SUP2-2GE SAD052202BY Hw : 2.2
Fw : 6.1(3)
Fw1: 6.1(3)
Sw : 6.1(1d)
Sw1: 6.1(1d)
WS-F6K-PFC2 SAD052304GE Hw : 1.4
3 8 WS-X6408A-GBIC SAL05268Y6V Hw : 2.0
Fw : 5.4(2)
Sw : 6.1(1d)
4 48 WS-X6348-RJ-45 SAL05268YUJ Hw : 3.1
Fw : 5.4(2)
Sw : 6.1(1d)
5 2 WS-X6380-NAM SAD052500WL Hw : 1.3
Fw : 4B4LZ0XA
Fw1: 5.4(2)
Sw : 1.1(1a)
Sw1: 6.1(1d)
6 2 WS-X6381-IDS SAD052504MS Hw : 1.1
Fw : 4B4LZ0XA
Sw : 2.5(1)S2a
7 2 WS-X6101-OC12-MMF SAD0521049C Hw : 1.3
Fw : 12.1(5c)E10,
Sw : 12.1(5c)E10,
15 1 WS-F6K-MSFC2 SAD05080SHR Hw : 1.2
Fw : 12.1(4)E1
Sw : 12.1(4)E1
16 1 WS-F6K-MSFC2 SAD051100RJ Hw : 1.2
Fw : 12.1(4)E1
Sw : 12.1(4)E1
NVRAM DRAM FLASH NVRAM
Module Total Used Free Total Used Free Total Used Free
1 130944K 57131K 73813K 32768K 6613K 26155K 512K 287K 225K
Uptime is 0 day, 4 hours, 26 minutes
sh log:---
Network Management Processor (ACTIVE NMP) Log:
Reset count: 47
Re-boot History: Jun 27 2002 11:54:41 0, Jun 25 2002 16:14:16 0
Jun 24 2002 09:55:22 0, Jun 18 2002 12:15:50 0
Jun 18 2002 12:08:51 0, Jun 13 2002 16:19:06 0
Jun 13 2002 16:12:51 0, Jun 12 2002 09:51:55 0
Jun 10 2002 17:20:48 0, Jun 10 2002 15:26:02 0
Bootrom Checksum Failures: 0 UART Failures: 0
Flash Checksum Failures: 0 Flash Program Failures: 0
Power Supply 1 Failures: 0 Power Supply 2 Failures: 0
Swapped to CLKA: 0 Swapped to CLKB: 0
Swapped to Processor 1: 0 Swapped to Processor 2: 0
DRAM Failures: 0
Exceptions: 0
Loaded NMP version: 6.1(1d)
Reload same NMP version count: 48
EOBC Exceptions/Hang: 0
Heap Memory Log:
Corrupted Block = none
NVRAM log:
01. 1/9/2002,12:26:56: RxSBIF_SEQ_NUM_ERROR:slot=1, pinnacleMask=0X1, errSeqNum=0,source Index=0X0, errorType=0X1
Network Management Processor (STANDBY NMP) Log:
Reset count: 47
Re-boot History: Jun 27 2002 11:54:41 0, Jun 25 2002 16:14:15 0
Jun 24 2002 09:55:21 0, Jun 18 2002 12:15:49 0
Jun 18 2002 12:08:52 0, Jun 13 2002 16:19:05 0
Jun 13 2002 16:12:52 0, Jun 12 2002 09:51:55 0
Jun 10 2002 17:20:48 0, Jun 10 2002 15:26:01 0
DRAM Failures: 0
Exceptions: 0
Heap Memory Log:
NVRAM log:
01. 7/17/2001,15:18:33: ha_swover_sync_status:static-db:1, dyn-db:0 (0-invalid, 1-valid)
02. 1/9/2002,12:04:23: ha_swover_sync_status:static-db:1, dyn-db:0 (0-invalid, 1-valid)
03. 1/9/2002,12:23:42: ha_swover_sync_status:static-db:1, dyn-db:0 (0-invalid, 1-valid)
04. 1/12/2002,21:55:07: ha_swover_sync_status:static-db:1, dyn-db:0 (0-invalid, 1-valid)
05. 1/23/2002,12:32:30: ha_swover_sync_status:static-db:1, dyn-db:0 (0-invalid, 1-valid)
06. 1/25/2002,14:03:52: ha_swover_sync_status:static-db:1, dyn-db:0 (0-invalid, 1-valid)
07. 1/25/2002,17:48:56: ha_swover_sync_status:static-db:1, dyn-db:0 (0-invalid, 1-valid)
08. 2/15/2002,16:17:11: ha_swover_sync_status:static-db:1, dyn-db:0 (0-invalid, 1-valid)
09. 3/6/2002,13:14:20: ha_swover_sync_status:static-db:1, dyn-db:0 (0-invalid, 1-valid)
10. 3/8/2002,10:23:59: ha_swover_sync_status:static-db:1, dyn-db:0 (0-invalid, 1-valid)
11. 3/27/2002,11:08:11: ha_swover_sync_status:static-db:1, dyn-db:0 (0-invalid, 1-valid)
12. 5/7/2002,11:57:00: ha_swover_sync_status:static-db:1, dyn-db:0 (0-invalid, 1-valid)
13. 5/8/2002,19:07:36: ha_swover_sync_status:static-db:1, dyn-db:0 (0-invalid, 1-valid)
14. 5/14/2002,18:07:36: ha_swover_sync_status:static-db:1, dyn-db:0 (0-invalid, 1-valid)
15. 5/17/2002,19:02:23: ha_swover_sync_status:static-db:1, dyn-db:0 (0-invalid, 1-valid)
16. 5/18/2002,19:54:51: ha_swover_sync_status:static-db:1, dyn-db:0 (0-invalid, 1-valid)
17. 5/24/2002,06:36:00: ha_swover_sync_status:static-db:1, dyn-db:0
1 REPLY
Re: reset problem on 6509 catalyst switch
You are running a very old CAT OS and MSFC IOS you are running is defferred. I suggest that you upgrade CAT OS to 6.3(7) and MSFC2 to 12.1(8b)E11 and it should alleviate most of your issues.
342
