Revers telnet disconnexion problem
Dear M. Expert,
i have built a samll network (10 ) router interconnect with ther Synch. interfaces. Each router have a an asynchronus equipement at is Aux. port.
The main router need to contact each ofthe equipement connect to the AUx. port and to do so i do a revers telnet. To make thing easeer i did a menu an a Ip alias with the port 6005, the Aux port in my router are the port (5).
Tje problem his each time i connect in one of a remote equipement wen i need to terminate the communication i need to do the ( ctl shift 6 x ) and (disconnect) commande.
This his much to complicate and long. His it possible to simplified this closing connection procedure and how.
Here his my configuration.
interface Loopback0
ip address 10.10.5.1 255.255.255.0
interface Serial0
ip address 10.10.2.1 255.255.255.0
interface Serial1
ip address 10.10.3.1 255.255.255.0
shutdown
interface FastEthernet0
ip address 10.10.1.1 255.255.255.0
speed 10
interface Async5
no ip address
shutdown
router ospf 10
log-adjacency-changes
network 10.10.1.0 0.0.0.255 area 0
network 10.10.2.0 0.0.0.255 area 0
network 10.10.3.0 0.0.0.255 area 0
network 10.10.5.0 0.0.0.255 area 0
ip classless
ip alias 10.10.5.5 2005
line aux 0
login local
modem InOut
autocommand menu choix
exec-character-bits 8
transport input all
stopbits 1
speed 19200
flowcontrol hardware
line vty 0 4
password luc
login local
escape-character BREAK
no scheduler allocate
end
Thank you.
Luc
1 REPLY
Re: Revers telnet disconnexion problem
There is no other way to replace those two commands..You need to use Ctrl+Shift+6+X followed by "disc"..
124
